Starting my ODST build
Sorry that I went dark, I got sick and had to head to Missouri Paracon this last weekend. I’ve attach the MKII top half of the helmet. The green glows :)
I might have a glowing addiction!
Now to finish my buck :)
How far down do I sand the bucks?
The smoother the buck, the smoother the visor. Imperfections like ridges, bumps, etc. will come through in the visor and cause a distortion in vision. Due to the concave shape of the visor its a little bit like looking through a fish bowl. So ideally the smoother you can make it, the better your vision through the visor will be.
In my experience a step down approach to sanding would be 120, 220, 400, 600(wet). If you want a SUPER clean visor a final wet sand with 1000. YMMV.
Does anyone have any tips for how to remove the plastic from the buck after it’s formed?
I'm a little confused. What happened? Is the plastic not coming off the buck? What am I looking at in that picture?
Sometimes the plastic won't come off if there's an overhang on the buck. Sometimes the plastic you're using to form is too rigid and won't bend away from the buck. What happens when you try to remove it?
Mb chief I read the old message. Excuse my 4th grade reading level
I’ll take a picture of the next form I do. Basically the visor forms so well the buck will not come out from under the visor. The pictures I posted the buck is nice and smooth, but appeared to create the c shaped scratches? Do I have to worry about that transferring to the visor?
Sorry on the vague post. I was trying to get the pictures up before the dentist started drilling. :(
Hey no problem with the slightly vague post. I just wanted to learn more about your situation.
I think those C-shaped scratches will show up in your next pull. I’ve never seen scratches like that though, that’s very interesting. There's a few reasons the plastic could have a hard time coming off the buck. If it's caught on something, if the plastic is just too rigid and won't ben away, or if it sticks to the buck for some reason. Seeing as it created visible deformities on the buck when you pulled it away, I would intuitively thing that that last option is the case, but I can't quite be certain what the exact cause was.
Those c-shaped patterns remind me very much of the pattern an orbital sander leaves behind when sanding low grit on a gummy surface. Did you sand the buck down after you removed the plastic? Or did those patterns immediately appear after you took the plastic off the buck?
Also, sorry if you've already mentioned this, what thickness and type of plastic are you using to vacuum form? And how hot are you heating the plastic to?
That’s the plastic I’m using for the visor. I wet sanded the buck until I was using 3000 grit. When I wiped the buck the Cs showed up.
I have been using the oven at 300 and letting the plastic droop until it’s evenly sagging.
The plastic looks like it should be fine. 0.02" is on the thinner side but should absolutely not be causing this issue. 300F is a good temperature to heat the plastic to as well. These C-shaped scratches are still a bit of a mystery though. It sounds like you did all of your sanding, then wiped your visor off, revealing the scratches. Is it a possibility that your sanding process caused these scratches, but you didn't notice them until you wiped off the visor because they were filled with dust? The scratches really look like what you get from an orbital sander. I don't see how they could be caused by vacuum forming. If it was the sanding that caused them, just make sure you wipe off your work piece thoroughly between rounds of sanding to make sure you can see all of the scratches that need to be sanded. Otherwise, the defects will be hidden until you wipe it off at the end.
I picked up some bondo spot putty and thinner to try a smoothing layer if the C show up in my next form. I’m going to have to the rest of the armor sooner than later :)
