Starting my ODST build
Sorry I meant for the Visor material when you vacuum form it. The transparent sheets of PETG. I printed my buck out of PLA on 25% infill and it was more than sturdy enough.
100% right about the visor material, but the bucks you usually want to print out of PETG for heat resistance and up the wall count to at least 5 walls. 25% infill is good too
I didn't mess with the infill. When I break this buck I will up the infill. I'm glad to see the gut hunch to make it out of PETG was a good call.
Honestly the wall thickness is going to be more important. You might still be fine. You can always try it out then up the strength on the next try like you said!
Does your frame pull down past the vacuum plate or just flush? I had bad pulls until I modified mine to go a little past the vacuum plate to insure a good seal.
It pulled past, but you couldn't feel any suction. I've since upgraded and revamped my build box.... Tomorrow morning I will run attempt number two.
I calked the inside as well.
I got it to form to the buck. Unfortunately, it exploded when I tried to remove the buck from the plastic. Am I using the wrong plastic? Did I let it cool for too long?
Here is the link to the plastic I used: Amazon.com
  • IMG_7615.mov
    4.8 MB
Don’t beat yourself up about it. We’re all learning here. I also tried acrylic at first, then transparent film, then bought the wrong PET sheet, and even set fire to a toaster oven trying to get it. You’re doing great. View attachment 357218
Have you tried using a Dremel to remove the buck on Acrylic? That may be a future attempt. The Acrylic formed beautifully, but was too brittle when it came to removing the buck.
Also, How did the toaster catch fire?
Love the way this is looking dude, keep up the good work.
I like the concept you have going on with the glow in the dark, it's a unique nice touch :)
Also don't beat yourself up over the wrong plastic, I did the same thing when first making my visor. I accidentally bought PET instead of PETG plastic lol.
Used birch plywood instead of MDF or aluminum for my frame. The wood was too close to the upper heating element and went up in flames. It was a great lesson.
