New member, start of a build
Personally... i don't know that I'd bother condensing. I'm a fan of printing in "one at a time" mode anyway. "Object Order" to this slicer.
Complete one part fully then the next. Much cleaner parts most of the time. Having 10 parts to a plate and all that travel doesn't reduce overall job time.
That's fair. I was kinda looking at it and was thinking it's gonna get pretty unorganized real quick if I try to do that.
Totally. I opened a feature request ticket with Orcaslicer hoping to get the ability to re-order plates.
There's a pull request from a develop who added a "move to front" ability that at least would let you move the current working plate to the first slot - it has not yet been merged however. But it would be a start on tracking what plate to do next, at least.
Should I print the whole knee assembly in TPU or just the kneecap itself?
Mine are all solid just because I like armor to be armor and I find it easier to sand and paint. There was enough room to wear a foam construction kneecap inside which both helps hold the part from rotating and provides a cushion when you take a knee. That's me. Next person might have a different plan that is more right for them.
Mine are all solid just because I like armor to be armor and I find it easier to sand and paint. There was enough room to wear a foam construction kneecap inside which both helps hold the part from rotating and provides a cushion when you take a knee. That's me. Next person might have a different plan that is more right for them.View attachment 351208
Yeah, I wasn't sure how easy TPU would be to sand and paint... I would prefer to not use TPU, but I'll see when I get there.
Update time! Taking inventory of armor parts and setting up what I still need to print. (Edit: Not all the parts are pictured here...and I forgot about the boot armor, so that still needs printed, but still...)
As of this time, the armor is completely printed! Onto the backpack!
While that is ongoing, I have begun the sanding process. And even though I told myself not to, I started with one of the most expensive parts, the buck. As you can see, I got a little to aggressive with it, and will probably need to add a little filler to it. I did figure out a good system for the other parts. I did 2 passes of 100, 240, and 600 grains and it came out pretty smooth using my random orbital. Will go back in with a mouse sander to try and hit the details. Anything too small for the mouse will get hand sanded, but that's gonna wait until the end.
Haven't posted an update in...over a month?? Oops...
TORG is nearly upon us, and I still have a LOT to do. My main goal is to finish my armor. Might not have time for my SMG, and certainly not enough for the backpack, but we'll see...
That said, who's ready for a photo montage??
First up, gluing the larger parts together. (Not all are pictured, but they're included.)
Glued up and eventually plastic welded (that process also isn't pictured...)
But here's an example of it on the chest and thigh pieces.
Sanding down the glue and some smaller parts.
Had a buddy print out some clear resin pieces. I see the red dot for the SMG...but wait..what's that other piece? Guess we'll see sometime down the road?
Test fit didn't fit. Will need to wet sand a bit and try and make it fit.
My sanded bin is getting larger than my to-be-sanded bin! Some still need the small details sanded, which I have since acquired the tools for.
And would you look at that? It's prime time to prime! (Sorrynotsorry) Hit it with Rustoleum's 2-in-1 filler primer. Need to wet sand and they'll be ready for paint!
Think I'm gonna go with a green. Seems I haven't taken a picture of it yet, so that'll be a part of my next update. Stay tuned!
Looking great! Here's to seeing it at TORG.
It's been a minute since my suit has made its appearance at TORG, and I should've updated since then... Ope, well, here we are. Anyways, finished the paint. And strapped everything up. The shins aren't great, but I'm hoping to fix that this week...before C2E2.
Also, I'm gonna upgrade my ¾" straps to 1" straps to hopefully give it better support, and use higher quality hardware. And I think I'm gonna remake the visor, but that's of a lower priority, as my current visor works.
Without further ado, the pictures:
Here's an example of what I used for my base coat:
The other spray paints I used:
Now it's all weathered. I used just a simple black acrylic to weather it.
Sadly, the weathering made it incredibly difficult to see my name and the UNSC tag.
Now onto the visor! My delve into this hobby was to encourage me to gain new skills and try new things. With that in mind, I decided to make my own vacuum former, and I think it turned out alright. I used a toaster oven to heat the PETG, and found out that I wasn't paying enough attention to what I purchased, as it wasn't pure PETG, so it's melting point was much lower. That lead to some issues when dyeing the visor.
While vacuuforming, I used some tape on the bottom of the buck to to hold it in place.
(Yes, those are 2x4s used to keep the PETG sheet up. And no, it hasn't caught fire.)
Can't see it too well, but got a few good pulls out of it.
And this is what happens when it's not pure PETG and you try to dye it...
I was able to salvage one of them well enough to make it work. I haven't sprayed it with the alclad, or whatever it is called. I forget, by now. But it's not super see through if the light isn't on the visor, and that's good enough.
So that's everything I had together by the first day of TORG. I may have stayed up until like 7am the day of to finish the strapping, but hey, that's cosplay for ya. Thanks to those who helped before they had to bed. I don't remember who all was there... I recall it was in Skidmorpheus's room, and I remember HoundsOfMeath being there. So thanks to those two, and everyone else who helped!
Now that you're caught up to what I had ready for TORG, time to show you the backpack!
Masking off the important bits.
Painted up and ready for weathering. Not exactly the same paint layout as in-game, but that's OK.
Now that it's weathered, we need to finish my waist down.
Which I apparently didn't take pictures of...
So here's a fun gif of the backpack... Just kidding. Turns out, I can't post gifs. Also, no videos, which is why I couldn't post me forming the visor. Also, the backpack isn't completely finished, but it is close enough at this point.
So here's the first picture of the full suit (ope, minus boot armor) together.
I actually won a competition with this!
And here's one from a photoshoot Fallen and I did last winter.
And here I am, loading up to drop at the Celebrity Car Museum in Branson, MO.
Hey everyone! I joined after talking to the members who were representing the 405th at the Kansas City Comic Con. I have not made anything prop or cosplay related before, but I've begun my own Great Journey towards making a suit of my own. Specifically, a set of Halo 3: ODST armor and armaments.
To start off my journey, I printed the Halo 3 ODST SMG from Galactic Armory. I haven't done much beyond print and test fitment. No sanding or anything yet. I just had to share because I was excited.
I still have to get the lens for the red dot. I'm not sure if I want to get the rest of the equipment I need to print it in resin (I only have a resin print, and no ventilation or wash/cure station.), or if I want to just order the part from someone/somewhere.
But that's where I am! Pretty excited to continue this journey as time is available. Will post updates when there are new things to update on.
It is a pleasure to be here and meet everyone!
that's so smooth what did you print it on?
Thanks! Bambu X1 Carbon, but it's all about post-processing. I did print them with as small layers as I could, just to try and save one sanding, but it probably didn't make much of a difference.
