1st Build Halo Reach Female build
I did something similar for my suit, but instead went to Tractor Supply Co. and bought horse-mat
The thick sturdy rubber you put on the bottom of stalls.
Attached it with a liberal amount of shoe goo and prayer, and it is still holding strong. I don't remember the price, but I'm sure it wasn't $50, and the mat was huge.
Update time!
I made one boot, and somehow that took me 15 days.
Acrylic to fix leakseal issues
Sometimes you have to trust the process and keep going... The final result might surprise you. :)
Scale check! (Paper chest and belt are 2 years old and will be redone.)
Thats all for now, bicep coming up next!
Also your 2 year old paper chest and belt look 10x better than my best attempts at foam
Thank you everyone! :love:
Oh man, those were the days I'd spend two months redoing one part... Now I just slather foam clay on the flaws and pray to the foam Gods it will turn out okay, so far it seems to be working. Thank you for the complements!
Hello, my lovely 405thers. I am desperately reaching out here after fiddling with a pattern for two weeks.
This is confusing, but bear with me.
Last October I made a thigh that fits to me perfectly, but I lost the templates and file. I spent a few days adjusting the size to find the circumference of the bottom of the thigh, and I eventually figured it out.
However, when I cut out a sample of the thigh and convert it to foam, I get a discrepancy of 2-3cm:
Not a big deal for some of you, but it adds up when you're my size.
Okay, no matter. I printed out some samples to put together, but once again, 6 mm and 8 mm foam curved "lengthens" the overall diameter of the foam when curved and enclosed. No matter what I did, even if I added bevels or separated the parts, there was still a huge discrepancy.
Armorsmith file with an accurate scan_____________Test build that devours my leg..............Discrepancy
The 13.5cm measurement on my test thigh measures 15cm across, and the 17.6cm measurement on my test thigh measures over 19cm. Once again, not a huge deal, but those are a simple length versus width measurement, not the entire inside area of the thigh.
The thighs height does not change because there is no extreme vertical curving.
This is where I come to you, desperate and tired, 405th. What would you do in this situation? The thighs are the only part of the Reach Spartan that is fully curved (with the biceps being somewhat curved) so I will not have this issue with any other part due to its blocky geometry. I do not want to cut the inside of the gasket to fix the problem because then the thigh will be heavily lop-sided, and I don't want to cut the front or back as it will have an unhideable seam. I also don't want to pad them as they are going to look far bigger and ill-fitted than the rest of my armor due to the errors. I also can't make a custom pattern with my original thigh, because the extra length issue will persist (tested). At this time, I cannot wait to make my thighs last as my chest and other armor parts are scaled off of them. I am not trying to be nitpicky here, I just want things to be true-to-scale out of Armorsmith.
I have already tried printing out several copies of the thighs, gradually getting smaller to test if I can find the right size with the foam discrepancy, but it is very time-consuming and full of error. Does anyone know a ratio or formula I could follow to estimate how much smaller I need to make the pattern to account for the extra length when the foam is curved?
Thank you as always,
Kae
That’s quite the conundrum.
I have an initial thought.
The first is around your printer drivers. I’m wondering if Armorsmith is exporting the templates for a printer that can print from edge to edge on the paper, while your printer driver may be configured to print with margins and will be scaling the content as such.
Are you seaming two pages together for the thighs? If you are, then I can print your template out on my 24 or 36 inch plotter and see if that changes anything.
Thank you for the response!
From day one I have always measured my templates that are printed off Pepakura. I usually grab a long, flat measurement from the unfold on pepakura and measure the same area on the print once it is taped together. I also can print a template that is quite a bit shorter in length and depth and get a similar size to what I am looking for when transfered to foam. I do not believe the template is the issue. However, I think I just answered my own question now that I have a clear head; manually shrink the length and width of the pattern until I find something I am happy with when transfered to foam. Oh, what fun! :lol:
Long time no see! I eagerly return to this forum thread, as my work ethic thrives off of community ideas and suggestions. I would love your feedback.
This Spartan has been a passion project that has now been years in the making. The hurdle that has always stopped me dead in my tracks is what scaling would look best on my frame: long torso and short legs, which is quite the opposite of a Spartan.
I referenced the scaling I used on my marine along with a game rip, and I came up with something like this recently:
AD_4nXd8ITo3ECIL65OqxnB1WfRmdVN-_TsDdG6qoGeKV5Ue9Oglr6EvDeyppfdlk117kcgHJS8i4m1KAZNejtusD1ikX4pS1vxYkBnQP-4SU6pEBJf-6QWFE1tz3JWM26FJ8d49Zt6v_Q
Note: 3D scan is incorrect, little red square under the belt is where my groin ends.
AD_4nXcY0StsxPwKxKLaY3XMjThq25WMtDg4nFoIXPqVcMEXwYONc6eoJQ__edagLheiVzPu48vgqpvKudCOHxdP4-WIJs9C4LUjuBwpg_WON4vUhPlQwvivguBUeXQLJUImoY8T4wF4
AD_4nXfsC1MNdIQleUxR9hBbxZlcv6o8O7VGaDL3oYK8XJkGEkjnBhvW56F74vBVWI44fAhSHKDNxtkmx1tlYfAx6hzHCmKf-J6B-fkKnHpelbwhAuY6AGjT2R2WZRDOxdvIbDi9h92SjA
Scaling can be a delicate process with lots of trial and error, especially when your frame is the complete opposite of the armor you’re trying to fit. If I make the chest and belt too small, the undersuit and neck gap will be too long. If I make them too big, and my legs look even shorter than they already are.
So, I spent this last month constructing a chest sample out of cardboard to see how it would look with the rest of the armor I’ve been testing. It's not “finished,” but good enough to get an accurate scale.
NOTE: Black helmet in the photos is from my marine. That helmet is very small, and not to scale with my Spartan armor:
AD_4nXcQRLsz2uqSOZpVlEbf4I1_hVqTHOrG1JUIAxfDbGEvJz5A8crhAVdV78FBJFhksY60W3jVvF_wqMEJE8obHFEy7qOz3lwwUxGMauMYxKywXSaaH6bTI6Cv8cjqpMbdzeYoDb6S
Marine helmet (Black): 79.43% 22.7cm X 30.7cm X 23.7cm
Spartan helmet (Pink): 84.60% 24.1cm X 32.7cm X 25.0cm
AD_4nXe9kFa8SconN8Y74j0faQDKhbSIwI6eKKj3tptxrbYBZv2OxbR7OwwUV7DNapyme7FKhCdz8XsIKkABblpe-Mo0GldRF1oHVG6VqVLPfMMUiryMcMJHIhOwNH2ulov0kgN6lqKo
Chest with “new” belt.
AD_4nXfj6Bg6hGO47YA7sHwXaSXMcsgAGV0NRfiUmYdT1o-dN3yXBgW6f_El5JQi9MAvlwk7zEGemLyCas0bE3GoJb45NEwsKiF8jGP9Hv_OqGbTbqC91ovGw8uBKWjBEmTOIe2ojb8rUA
Chest with “old/outdated” 2021 belt.
AD_4nXdTqqPRMbha1OeMMzkZ9d3Xc53X8N27Nh0DtcteU8LoI6i_pUmQUSxbNTpS0ODSSbCMC4vU_OJGDTfgV7EdtLlAnyr0h904DyAtFUSY5s6FTDv-jOA5ov30i-XYUX_exd-iw5ek
AD_4nXfeKzRbnaUlOLl0PCkwY3uTr3dnfvkws1BaxqU7C4FfnZS-pC4I6NTRjEHE5BUECELYVnhhr20dlPwszjFEk6urubtmKWHrN8K9K9xv4aO5gIFpRF19q7kmEE7ppau0osVFtYq9CA
AD_4nXdaNkfJLYSbh6vvTpM-6V6R_aZH8iQdxfixSdIqXW1G_VRDi6ad_nT1LtyU1ozX6fxJHxizGFXI7F77qHo0_4NygGqHMMp9zVnRwZG8n61heE5-q5739KWiAn4yFa0yNoUt8IbF8g
AD_4nXfm4xcdpPfRvKKWSTInejvPqtG4px7X7q1MA_uphm9sXhn7GtMEawZTrvQ4KSeHIfG04xwAPYK-XoT6tZaLj4qfyPAjIgIGapn2CoPNfxecmYKq5oQrGi0cI77uP0W5Zj7xV-HuBw
AD_4nXcUskGklYP0imoUxfsAwrKEMpgzAIJQyTg5lho2WkSPkXJ8DEJZap8osy2OadApldnbJKnHAt8h4OIPpoJOIRHgS3Z48ekliYveV6sB2HsbzdXYfUeJCgh7BDsP47u1_i3A5511_g
Here are my notes:
  1. Concerned about the helmet-to-chest-to-belt gap.
Chest gap may be too big unless I hike the belt way above my groin. I do not yet have an accurate helmet with an accurate length, so this may be resolved when it is printed.
  1. Concerned about making the chest and belt bigger to fix the gap issue.
While the chest gap can be resolved by making the chest and belt larger, it is a delicate balance. Enlarging the chest and belt would make the armor too “deep” to fit in, and would also make my legs look too short. Would it be worth keeping the belt gap longer to keep my legs proportional in length?
  1. The Side profile is fantastic, although the depth of the chest uniform-scaled may be too deep.
  2. Leg armor fit is perfect, but also allows room for weight fluctuations. Boot CANNOT be scaled up without risking mobility.
As someone who thrives off of community feedback, I want to hear from you.
  1. What are your thoughts overall? Anything that catches your eye scaling-wise?
  2. Thoughts on helmet-to-chest-to-belt ratio? How may I fix this issue besides hiking the belt way above my groin?
  3. Any other tips or suggestions.
Thank you!
3 am time to post.
As I was telling you earlier it looks like your toso is a little long (Front to back) and a bit tall (top to bottom) and could use a but of non uniform scaling to fit it better to your body and new helmet.
I agree with KitKatGoose. I wouldn't go any larger on the chest piece. An ab wrap or something to add texture to the place between the pieces will make it look 'fuller'. I also wear my cod piece pretty high to help even out the spacing between the chest and thighs. And yes a slightly larger helmet as well I think will look even more accurate.
I can see where frosty is coming from saying it's a bit long front-to-back. I think it's worth making the chest piece at this current scale, and if need be taking a small section out to make it less "deep". I had to do that with my chest piece. I removed like 3-4cm to bring the front and back closer together, while keeping the rest of the armour the same scale. Since you're using foam you can always do that once you've build it though.
It's looking so good!! I definitely don't think the chest needs to be any bigger, the gap between belt and chest looks totally fine to me and will look even better with the undersuit detail filling it out. And with the slightly bigger helmet and some arms I think this build will look super well balanced!
I have concerns about how high my belt needs to be hoisted up, but scaling the chest or belt up would make the legs look off. Thank you for your input!
3 am time to post.
Thank you, I will think about this comment more.
Thank you for your input! I agree that I should go ahead and continue with the chest being at this current scale. It shouldn't be too difficult to remove a bit of foam from the inside, but it would be difficult to add more.
Thanks everyone, I truly appreciate your feedback.
Halo characters have always been off just a little bit. Over the years they have gotten much better, but you will never be able to match the dimensions of a Spartan from Reach and still stay a healthy human.
So far your work looks amazing, and the scaling does not look that bad. I might caution about the helmet hitting the back of the torso if either or both get much bigger, and that will be super obnoxious, so be careful.
Your belt-groin-torso issues look to me like they are more in your head than in your scale. You will want the belt "hiked up" to where your pants' waist usually rides, and otherwise just make sure your undersuit is tight-ish, and not baggy. Avoid making it super tight though; it can get way uncomfortable otherwise.
Beyond that, putting detail into your undersuit will solve a host of concerns, so don't fret too much about the amor.
This is looking fantastic! Keep up the good work!
NOTE: (This will be cross-posted to my "FEMALE ARMORY OVERHAUL" HERE as it is relevant.)
After months of troubleshooting and work... I am FINALLY DONE with the female chest overhaul! This was a labor of love for the ladies here that felt uncomfortable and left out.
The original file was from the armory:
  • halo-reach-mjolnir-mkv-chest-female-foam.pdo
    Modeler: L3X BLU3R1V3R
However, this file is incredibly outdated and does not fit the average female. (I am 115 pounds and could not fit the width or depth of my torso without making the chest ginormous) So I decided to give it an overhaul!
And here are the comparisons between the original file (Cyan) and my overhaul (Pink[white are optional foamies])
I have two versions of the new chest, one with the seams/grooves:
However, I knew this would make the Papakura file way too stressful to use, especially if someone did not want to do all those seam details, so here is the final product that is more foam-friendly with flat guides that allows someone to CHOOSE if they want to inset the seams or not make them at all!:
Optional foamies as well!
Comparison with the game-rip:
!!!!!!!!!!!!!!!!WARNING: FLASHING OF MESH!!!!!!!!!!!
Pepakura view:
I am so excited that my labor of love is finally done! So many hours of work (and tears) went into this. I am going to test the pattern on my build, and if it works, I'll be happy to give the file out for free. non-commercial use.
Thanks for tuning in, off to craft!
Kind regards,
__Kae
